spoolin ddub
- 598
- 17
- Aug 24, 2007
Chicago,
Illinois
Here is some good info to read. This is from a Evo 8-9. Yes I know they are two different motors but I use the numbers as a reference to convert to DSM specs e.i. intake duration @ .050 lobe lift: 211.5 is universal on cam analyzer. So the breakdown speaks for itself and gives an idea of the real numbers vs advertised numbers.
4g63 Camshaft Research: The truth shall set the tires free!!
It gets really good when they get to the Evo 9 FP4R cams on the cam analyzer. Here are the advertise specs of the Evo 9 FP4R version 1 & 2. Both have more duration then the DSM FP4R (from what I have researched every evo cam has more duration then the corresponding dsm cam).
http://store.forcedperformance.net/merchant2/graphics/info/camcards/evo94rv1.pdf
http://store.forcedperformance.net/merchant2/graphics/info/camcards/evo94rv2.pdf
If you want to cross reference here are some evo cams at 1mm advertised duration. Also Jun 272 peak lift is advertised as 10.8 but shows 0.41829 =10.6mm on the cam analyzer.
Cam Specs Thread - Updated - evolutionm.net
I will say this. I have to give props to Darren at FFWD. He is the only person my machine shop and I have ever seen that posted the true specs of cams on a site. They have always been there. Most just dont understand them.
DKS 3 Camshafts - DKS Camshafts - DSM/EVO
