wreckshop56
- 132
- 0
- Aug 14, 2003
1000 AAQ - Terms
Crankwalk is a tough thing. When driving the car, you can generally tell because it feels like the clutch isn't fully disengaging, especially in left hand turns. The only real way to check is have a knowledgeable mechanic pull the oil pan and check the crank play. The only fix is a six bolt swap. The only good news if you have crankwalk is that it gives you an excuse to build a new motor. Good luck with the buy, the GSX is an awesome car.
Ok so is it in the block? and a 6 bolt swap is that the full engine or just the block? i dont know that much about the turbo eclipses as u can see.. so when i make left hand turns the clutch would sometimes be fully pressed in?
outta the car making left hand turns and listening for wierd ticking noises from the timing belt area...and consider doing a rebuilt 6bolt block
.. plus the hole on top of the tranny for the mount is stripped too.. who do i go to for re threading
Good luck.
hehe
