soldave
- 737
- 2
- Feb 17, 2008
Okinawa, Japan,
Asia
This damn rebuild is one step forward and then a giant leap back coupled with a kick to the groin. Taking the timing belt off before and you might have read that the timing belt tensioner "special tool" I'd made was feeling a little tight to unscrew, so I elected to wait until the head came off when I could get some more leverage on it. So I did that tonight, cranked it around a few turns and low & behold the threaded rod snapped. I now have about 1/2" coming out of the inner timing belt cover, and on the other side I have about 1" still all the way through.
Question is what do I do now? I tried double-nutting it on the timing belt cover side but it was just pulling the nut off the rod (think the threads there are warped. Only thing I could possibly think of would be to cut into the timing belt cover and actually try and screw it all the way through the other side (would be very tough as tensioner side I'd have to bend the rod and there's not much space to play with.
Any other ideas before I contemplate drinking myself into a stupor?
