Tell me what this ecu is please
slonkey
225
Apr 9, 2012
ST.Louis, Missouri
Fiend gave me a Ecu for a eclipse no year was told. Just some info please. Emrom?
How can u say FWD specifically? Turbo ECU's are the same FWD and AWD, im using a ECU from a 95 GS-T in my 96 GSX....SMDH!
If it were an eprom, there would be a long rectangular chip on the bottom right corner of the circuit board.
Although FWD turbo and AWD ECUs are interchangeable, they do not always have the same part numbers and are, as one would expect, not exactly the same in those cases when they differ (see: speed limiter). In fact only '95 models shared the same ECU between FWD turbo and AWD; all other 2Gs have different part numbers between the two.
The one pictured in the OP would be a MD335287; the AWD '97 ECU would be MD326328. The E2T6 number (the number on the white portion of the unit, 1687) is the tell and was referenced here: Eclipse Talon Laser Galant 3000GT Stealth ECU ID Reference.
That's how I can say FWD, specifically.
Cheers.
No without an EPROM unit you can not use an ECMlink the EPROM is necessary to swap in the chip they send you in the kit.
If its a 95 or 97 it can be socketed and coverted. I had them do that to mine. Mine is a 97 ecu
How much is a switch over? To socket
Is it 185 for the whole package or just a chip?
$185 is only for the conversion to an EPROM ECU. ECMLink will ultimately cost more. E-mail Tom or Dave at ECMTuning and they'll be able to tell you all about it much better than we can.
Edit: Uh... ^^^that. Way slow...
