Please Tell Me What Is Going On?????
Clipse16g
Jun 1, 2005
elizabethtown, Kentucky
alright, first i have a 96 gst with a GReddy 16G and a ram air intake BOV and thats basically it for the motor, anyways i was driving tonight and i kicked it, well when i hit 5000rpms it started kicking, like it wasn't going smooth, someone plz tell me what they think it is. thanks alot for your help
Check wires, plugs, your vacuum lines, your ic piping. Those can all be related to the your car is running.
i just changed my spark wires and spark plugs, does this sound like a boost leak maybe?
what it does is, it's running smooth up until the 5 rpm range than it will feel like your slowing down then it will raise the rpm a little then it will stop, it's weird, nothing i have experienced before until now
gurrmanator said:
find out your fuel pressure,fuel pump could be starting to go.
how much boost? no fuel managment, injectors? can you say fuel cut?
it's running stock boost, maybe 8-10? i was thinking maybe the fuel filter? or the fuel pump
small 16g, big 16g, evo3 16g? im sure some people know the flow numbers of those turbos and can tell you if those will hit fuel cut at 10psi....
edit: didnt see greddy 16g, nvm....
