t28 supporting mods.
jprevette336
Nov 9, 2013
winston salem, North Carolina
i have quickly learned that the completely factory 1998 gst isnt factory as i thought or was told. i have come to find out that the balance shafts are deleted, its got a aftermarket cam (not sure lift or duration), and a big garrett t28. not to mention what ive done to it, GSC valve guides, new valves, 4 angle valve job, ARP head studs. i have the stock injectors but i feel that the cars running lean (plugs are white.) my question is do i need anything else?
What kind of budget..you could get 190 fuel pump bigger inj and a safc or for more money I run dsmlink ,bigger pump n injectors ..etc its a fun lil turbo search t28 fuel mods tons of good info
550 or 650cc injectors, fuel pressure regulator and a 255hp fuel pump. Add in wide band, safc or link and a boost controller then you can run 23 psi all day
my future plans are evo 9 injectors, a wally 255, wideband, oil pressure gauge. what fuel pressure regulator do yall recommend? also what boost controller do you think is best?
