Sun-Burned ’99 Spyder GS: Revived
2.4L DD
Great build. Appreciate your details and pictures.
Glad I found this thread again, love the attention to detail you have on this car! Keep the post coming, I'm waiting for an after picture after the seals added on the bows.
Thanks. We just finished gutting the interior to install sound deadening, and while we had an empty interior, we FINALLY tracked down the source of the rain leaks. It wasn’t where we thought they were.
Here’s a link to the article:
https://www.dsmtuners.com/threads/sealing-the-most-common-leaks-in-spyder-roof.523613/
14. Full Interior Sound Deadening
Those of you who spent hours scraping factory sound deadening from your car to save weight will cringe at this step. For daily driving and occasional touring, the "DSM drone" gets to you after a while. So, we installed Noiko sound deadening mats. They are constructed of about 2mm of rubber, with adhesive on one side, and an aluminum vapor backing on the other.
At first we thought that simply removing the seats, console and carpet would give us enough access to the resonating panels, but we quickly learned there is no good stopping point, so we wound up gutting the car from dashboard to taillights. This turned into a bigger project than anticipated, but that pretty much describes every project ever undertaken on this car, LOL.
Here are the basic tools you'll need. The red marker makes it easy to see your marks on a black surface. The material will cut easily with a scissors for the long cuts, but the razor blade will help with corners and any overlap.
Removing the factory brittle sound deadening:
Rust preventative spray on the any raw surfaces:
We'll take as much help as we can get:
All prepped and ready to start installing -- or so we thought:
When installing the sound mats, do not precut them! You'll wind up with gaps around the edges of the area you were trying to cover. This is because the floor and braces are not straight or perpendicular to each other. Just peel the backing, start at one corner, and begin pressing down. You can cut the edges when you are done.
The manufacturer also talks about rolling the mat tightly onto the surfaces. At first this seemed like overkill, but we soon discovered that air pockets left under the mat will turn into pools of condensation and could start rust. Buy a roller and roll it tight.
Here is after the initial installation:
The trunk sides were going to be hard to do given all of their bracing, vents, wires and lights, so we decided to do the backs of the panels instead:
Here are the pictures with all the tunnel mechanisms and wiring bolted back in, and here is the padding we added for under the carpeting and under the rear seat:
After it was all back together, we did quite a few daily trips and then, a 350 mile road trip. The result is not a complete sound proofing of the interior, but it does dampen the exhaust drone, and, just as importantly, the tire whine. It feels like a more substantial chassis. The results are noticeable.
15. Upgrade to GSX 4-Wheel Disc Brakes
The front disc/rear drum setup on the car provided adequate braking modulation, but didn't inspire confidence to push the car through corners on twisty roads. Plus, the heavy weight of the rear drums was not doing us any favors in the suspension department.
We ordered a set of GSX spec disc brake calipers (dual piston front; single rear), ceramic pads, new rotors, stainless brakes hoses and new ebrake cables (since the end fittings are different). We sourced the disc backing plates from a donor GSX and had them bead blasted, and then we seal painted them with POR15 with rustoleum top coat.
There are a couple write ups on how to do the conversion from rear drum to disc, but there are two things none of them mention: 1) Don't forget to buy bolts to attach the rear calipers to the backing plate. The size is M10 x 1.25 x 10mm, You'll need four of them. 2) Getting the clamps off the parking brake cables, and getting those lines out of the car is the most difficult part of the job. This is a Florida car, with virtually no rust, and yet those cable clamp bolts were corroded and tight. There are three clamp points for each ebrake cable, and 4 per side if you count the inside floor tunnel. The rear two finally came out with a little break loose spray, but each of the outside front ones had to have the bolt cut. We were VERY fortunate that our exhaust had v-band connections so that we could remove the back portion and get to the left side front clamp. Those cut bolts were replaced with stainless steel hardware, and everything we unbolted and reattached was slathered in anti-seize.
Here are the pictures of how the process went:
Rear drum brakes removed and the new backing plate fitted into place, with the hub beginning to be reattached. The ebrake setup was difficult to install after the hub was in place, so on the other side, the ebrake components went on first.
The finished front brake with the dual piston calipers. The disc is painted with high temp brake paint on both sides of the hub area to prevent rust from seizing it onto either the hub, or the wheel.
One side complete. A good friend helped with the project, but with the difficulty of removing the existing ebrake cables and a parts run for bracket bolts, it was a solid 9 hour project, start to finish.
As for the new feel of the braking system, it isn't a more sensitive pedal response, but when you do press into them, there is a lot more clamping force available. They are easy to modulate, but that is on the second half of the pedal travel. Apparently, a 3G master cylinder has a more firm feel due to moving more fluid per travel. We might upgrade to that depending on how the pedal feel is after the pads break in.
[QUOTE="Widgmaster, post: 153775685, member:165098”] ...Just thought I would mention a color back solution to a black faded top . /QUOTE]
Thanks. That looks promising. We’ve been looking for something like that. We’ll give it a try.
16. Forced Four & Manumatic Shifter
So we've been wanting to add the Forced Four Shift Controller to this build to protect the transmission with increased line pressure and to add better shift control during all driving situations. We also wanted the 3G manumatic shifter for bump up and bump down shifts.
I talked with Shawn at FF and explained to him that we wanted firm manual shifts, but softer auto shifts for daily driving. He determined that we would be best off running the FF controller in PARALLEL to the factory TCU, and switching between the two to get the Jekyll and Hyde personalities we were looking for.
This arrangement makes for a little extra work, but again, Shawn was very helpful in answering all of our questions.
To make sure we knew what gear we were in in the manual mode, we ordered the digital gear display. We wanted it somewhere in our line of sight, but really couldn't find a place to mount the cased version without drawing attention to it, so we decided to put it into the dash display, in the spot that previously had the "A/T Off" light, since that was no longer going to be used.
A. Dash Gear Indicator
The first step was to remove the gauge cluster from the car and disassemble it.
Here are the screws for removing the gauges. Caution: Each gauge uses the attachment screws to conduct electrical signals between the circuit film and the gauge. These screws are different sizes for different gauges. Don't mix them up or lose any of them:
We removed all of the gauges and light bulbs, and then peeled off the circuit film:
Since the gauge cluster plugs into fixed male connectors behind it, it is important to let the cluster assembly travel all the way back when installed. Fortunately, there is a hole behind the cluster for the display wire to pass through:
That means that there needs to be a hole through the back of the cluster housing to let the FF display wire through. Of the four screws holding in the speedometer, one of them is a non-electrical connector that lines up almost directly with that hole. We needed to enlarge the screw hole to 1/2" to pass the display connector and wire through:
However, the FF plug had grip tabs on it, making it not fit through the hole, so we filed off the tabs so that it was only 1/2" in size. Here you see the before and after pictures:
We carefully slit the circuit film to allow the plug through. Then you can see how it looks when the wire is in the final position:
Next, we had to slightly modify the display by removing the center light lens and notching the mounting area for the display led:
This display was glued into place and then we placed foam around it to make sure there would be no light leaking when the gauge lights were on. Notice that some of the previous tinted light lens had to be trimmed and reinstalled above the display:
During the trial fit, it became obvious that the led display was just slightly wider than the opening in the bezel face, so we had to widen this area slightly:
We reassembled everything and tested the unit display. This picture makes the led look dim and overlit, but no matter how we took the picture, we could not show that the numbers were actually bright and crisp:
Here it is installed in the car:
We are extremely happy with how it turned out and are ready to begin the second part: Installing the manumatic shifter and FF Shift Controller.
Installing The ManuMatic Shifter
The moment of truth: Switching over to the 3G manumatic shifter. We had already read the steps and tips from @TheFlashDSM, but our installation is going to be a little more involved.
We had read that the 3G shifter sits farther forward than the 2G. Using the existing mounting holes, this is very true. So we decided to use a manual shift boot rather than try to somehow modify the shifter trim plate in the console. Someone could probably do a 3D printed version of one, but we aren't set up for that. Besides, the conversion has already taken longer than planned.
As an unlikely first step, you have to modify the shift boot to be 2" shorter, otherwise the extra material bunches up at the front of the shifter and prevents you from putting the lever all the way into Park.
Here's the full height of a manual boot:
Next, turn the boot inside out and pop apart the plastic grommet. This one was zip tied but not sure if that was factory:
Turn the boot right side out and measure the 2", and cut it off:
Turn the boot back inside out and reinstall the grommet. Turn it right side out again, and you are finished:
Special Note here: Because the 3G shifter sits much farther forward, you *might* have to remove some of the plastic trim ring in the boot as needed to let the lever move all of the way into Park (see Update note below). Here is the ring underneath.
Notch the center of the ring:
Now the boot is ready to install:
Here is the stock 2G auto shifter:
Pulled that out:
Bolt in the 3G shifter:
The Brake pedal release cable bolts right up with nothing but a little bit of adjustment, but the Ignition interlock cable requires a large washer to hold it further forward on the housing. The shifter post will not let the Transmission linkage cable slide on without first filing the nub on the end of the post off. The post is disappointingly soft and files fast. In the pictures you can see we drilled through it to add a cotter pin for safety.
Brake release and Ignition interlock cables:
Transmission cable:
DO NOT FORGET to adjust the shift linkage:
So here is the finished installation. Showing the lever in Park, in Drive, and in Manumatic mode:
We're happy with the results. It shifts like butter, especially considering that the transmission linkage cable now crosses over to the driver's side of the shifter. Can't wait to get the wiring done for the FF controller to make the most of the work so far.
2025 Edit: With the 3G shifter sitting so far forward, we notched a piece of the plastic boot frame (shown in the pictures) , but even that did not allow for engagement of the Park position 100% of the time without a little extra “push” once in a while. It needed just a little more travel. We stumbled across an old thread that mentioned lifting the front mounting point of the 3G shifter for better fit. We did this spacer mod and the positioning is great now.
1/2" spacer installed under front shifter mounting bolts:
Wiring The ForcedFour Controller
Just a note here: It is not necessary to run the FF and the factory TCU in tandem. We chose to do that so the car would retain its factory operation in case we were not able to replicate the programming with the FF. After living with this installation a while, we were glad to have done this because, hard as we try, there are shift commands that Mitsu has in the factory TCU that feel more intuitive and smoother when auto shifting, but we'll keep working on the FF programming.
Since the stock 2G shifter had a button on it to engage or disengage Overdrive (4th gear), the first step is to snip and solder the two wires together to make the factory TCU think the OD button is still present and is in the OD engaged position.
Here is the plug location on the 2G shifter. The wires are Black and Red, but on the harness side of the plug, the wire colors are Blue and Red.
We mounted the ForcedFour on top of the factory TCU. We used velcro to allow for some repositioning if necessary, and during the on car wiring, it turned out to be a good choice. We could relocate the FF unit temporarily to gain more room.
Next to the FF unit, is a 5 pole relay that turns one TCU off and the other on and vice versa. Shawn cautioned us that this was necessary to prevent damage to either controller. The on/off function is controlled by moving the shift lever from auto into manumatic position.
Behind the relay, is a switch we added. Flipping this switch allows the FF unit to take over automatic shifting control in case the factory TCU were to give out. It's doubtful that this would ever happen, but better to have the option now that all of the wires are so easily accessible.
Don't let this picture scare you away from installing your own ForcedFour controller. We were simply separating the wires into the groups of where they will be connected.
Edit: Maybe this picture should scare you just a little bit. The cramped footwell and short leads to the factory TCU make this one of the least favorite wiring jobs we have ever tackled. It's not complicated but it sure is cramped.
Wow, your car is turning out amazing!
Thanks for the heads up on the caliper bolts. I am in the process of tracking down the parts to do a rear disc conversion on my RS down the road, and those were not on my shopping list.. That would have been an unpleasant surprise, LOL.
Btw it looks like you accidentally tagged me in your manumatic transmission swap. I didn't make a write-up for that. 😁 It looks like it turned out great though!
Thanks for the compliment. We do mods to make driving more fun, and manual gear control will definitely be fully enjoyed.
You are correct, we were thinking of TheFlashDSM who did the write up and pictures. We fixed the tag, and glad to have you following along.
Thank you. We’d seen it done on a couple of other cars of different brands over the years, so it was a go to when the shifter plate wasn’t even close to fitting. Many new import cars, such as Hyundai, come standard like this now for the cvt’s.
We were thinking of you when we discovered how thick the leather boot was, hindering shifting into Park. So far it’s working well.
Looking at your picture of the shift boot you are cutting... that is not leather... it is Naugahyde / Vinyl ... I can tell by the backing on the boot you are working with.. Good quality leather is even thicker than Naugahyde .. Any ways it`s a great job you did.. I`m impressed ...and what you did with your interior is beautiful.. If I still had my shop I would offer you a job......LOL
Daily Driving With ForcedFour
After that less than fun wiring portion, we were sure hoping that the ForcedFour would meet our expectations in terms of control over the shifting characteristics and parameters of the transmission.
It did not disappoint.
Shawn has made several improvements through software updates that have simplified the setup process, without sacrificing choices. Out of the box, ForcedFour is setup for instant shifts - no delay -- that can be pretty harsh for street use at partial throttle, without the "soft shift" feature activated. Even then, you may still want to dial in a few mS of delay to save your drive axle u joints and engine mounts.
The FF unit has been very consistent and predicable, offering gear control just as surely as if you were driving a manual, with no clutch operation to slow the shifts, and no clutch to bleed, adjust or replace.
We are battling a TPS issue. We're using a 1G NT TB with a swapped 2G TPS. Although the TPS operates fine for the ECU & TCU, and checks out on EvoScan, it does not register as a variable value on the FF software. The wiring connections have been double tested for continuity, but when the car is out of storage in the spring, we will test the FF TPS lead for variable voltage. Without being able to read the TPS, the FF thinks partial throttle is WOT, and the shifts are very hard, unless we open the throttle and accelerate, or lift off. We are looking forward to getting this last bit of programming finished so we can enjoy the FF unit to its fullest, without any special situations.
Because the shifter is a manumatic and we retained the stock TCU to handle auto shifts, we do sometimes forget, daydreaming at a stop light, that the shift selector is in manual, and try to leave the intersection in 3rd or 4th gear. Because of the torque converter, it can be done, but the best way is to pause a couple seconds and bump the selector down to 1st gear, or flip over to full auto, and try to drive away before anyone notices our mistake, or honks, LOL.
But one of the biggest improvements by using the FF, is freeway ramps. Being able to control the gear without the car thinking it needs to downshift to accelerate is peace of mind.
Hilly and curvy open lane blacktop is also great to select exactly the gear you want, rather than worry that too much throttle input will trigger a downshift.
These are examples that manual transmissions enjoy every day, but the overall advantages of the ForcedFour shift control is the ability to return to auto operation at any time, no clutch and related equipment to service or replace, faster shifts, and a stronger transmission to use when adding horsepower to your build.
We'll update the thread with the solution to the TPS mystery this spring.
Here's the promised update. "Spring" somehow turned into "Fall" before I got around to checking the TPS wiring issue more closely.
Shawn @ ForcedFour was right, it was a wiring issue. Although the TPS connection tested good for variable voltage without the unit plugged in, by plugging in the connector and repositioning the FF unit made the TPS wire tap internally lose connectivity, thus no TPS signal. We modified and secured the tap connector to make sure it did not disconnect.
Now all of the programming in the FF software works accurately since the Smart 150 no longer thinks we drive everywhere at full throttle! LOL
We'd be happy to help anyone considering adding one of these to their automatic. It really does change the way you enjoy and drive your car. And isn't that really the ultimate point of all of the mods we make to our DSMs?
We've just about got the Forced Four dialed in how we want it for shift characteristics as the low and mid throttle positions. It's going to be a 2 person job to set the shifting for the higher speeds. FF has increments of 0, 20, 40, 60, 80 & 100% throttle where you can adjust the engagement speed and firmness. It will go better with someone watching the laptop for when those increments are achieved for repeatable adjustments.
The AC system was tired and keep leaking, so last Fall, we installed a new AC compressor and condenser, drier, hoses and seals. Not as difficult a job as we expected. Both coolant temp sensors replaced and flushed/filled all fluids.
Then we put on a new set of Continental Extreme Contact tires. The 1/2" taller height and slightly wider size increased the footprint to help the car feel more planted; less twitchy at speed.
Next, the front hubs and axles, new harmonic balancer were installed by a trusted friend with a heated shop and lift. The old bushings were completely compressed and torn as were the boots for the lower ball joints. After an alignment, it drives so much more composed when doing a directional maneuver or hitting road bumps. So glad to get the front end updated.
After this work got finished, my wife and I took the car on a 2,000 mile trip to Florida and the car ran great! The irony of replacing the AC system was that it was freezing weather all the way to the Florida state line. Oh well, it would be ready for Florida heat when it happened.
Here is the write up about our trip with pictures:
19. TPS& ISC Replacement
Close to the end of the trip, the car began starting up too rich. After it warmed up, it behaved normally, but, as I found out later, the new coolant temp sensor went bad (Standard Motor Products) and the Biss screw vibrated to fully closed.
To make sure this was cured this once and for all, we replaced the coolant temp sender with a higher quality unit (Duralast -- at least it reads correctly out of the box) and decided to replace the old original TPS sensor and ISC at the same time.
When testing, the old ISC would only move one half of it's distance. It was just tired. The TPS was a bit of a challenge because we run a 1G N/T throttle body with a 4-wire TPS. We ordered an OEM Mitsu TPS and when it arrived, we were surprised to find that the OEM TPS would not lose connectivity on pins 3 & 4 when the throttle plate was closed. It needed more rotation, so we devised a way to make that happen. That write up and pictures are here:
Once all three of these steps were done and the Biss screw seal replaced and correctly set, the car starts, idles and runs great. Wish those parts had been replaced a long time ago. Even off idle and pedal response is much improved. Gas mileage should be better too, but we haven't taken the car any long distances to get a comparison.
20. 2023 M.O.M. Show
Finally had a chance to take the car on a long trip. We went from Naples up to Kissimmee for the 2023 M.O.M. Show (Mitsubishi Owner's Meet). It was great to be immersed in everything Mitsubishi again. Here's pics of what we saw at the Show:
Got excited about getting to the Show, so we didn't get gas mileage calculations on the trip. Had fun! Don't care!
Drove the Spyder back the 2,000 miles to MN. A very enjoyable trip since everything was working correctly. We drove through a couple national forest areas with twisty roads and beautiful weather It was exactly what the car was built to do and gave us the opportunity to appreciate the beauty of this country. Even got lost once in Kentucky on a sparsely travelled road, and a local came walking by and got us turned correctly.
The thread covering the return drive, along with some pictures will be in the "2,000 Mile" thread in the Hangout section.
21. Rollover Switch
Since eliminating the problematic fuel relay solenoid and switching to the '99 GSX (programmable) black box ECU, the fuel pump stays on when the ignition is on. We enjoy the faster starts with full fuel pressure.
The concern is that the fuel pump could keep running in the case of an accident, including a rollover, on the street or track, and if no one knew to shut off the fuel pump, it could turn into a dangerous situation very quickly.
So we installed a fuel pump shut off switch that kills the power to the fuel pump in the case of a high impact.
These switches are used on many cars and sometimes get a bad reputation because they are so inconveniently located to reset, if the heavy impact turns out to be a huge pothole, or -- heaven forbid -- a curb. To counter this we wanted it mounted in the cab. But where? The large red button isn't stock looking and could easily be in the way for normal driving.
Under the console would have been nice, but the size and height of the button made that impossible. So the area under the package slot, below the radio was selected. There is plenty of room to mount the button in the upright position it is required to be in.
To provide access to reset it, a finger sized hole was drilled.
Hopefully, the function of the button will never be needed, but now we can rest easy knowing the pump will shut off to stop the engine in the event of an emergency, without having to rely on responders to be initially involved.
Love what you’ve done to the car so far. Curious to see how it does on the dyno.
Thanks. It feels solid and has become a very comfortable daily in the sunshine.
We should go back and add that info about the first time it was on the dyno right after installing the '99 black box ecu. The tune was good, but not sharp since with an automatic you can only pull so hard in third gear without triggering a downshift. Annnnnd...the header collector gasket cooked/blew which is ahead of the O2, so the readings were not real reliable. With the addition of the ForcedFour shift tcu, it should be easier to tune since the tech can do hard third gear pulls.
Ironic and frustrating, one of the runners in the eBay header (4-2-1) now has a hole in it so that has to be addressed before the dyno session this summer. It was the only N/A header we could find. Unfortunately, a whole new header is probably the answer since the thin wall tubing may not weld well. We're currently checking our options.
We used the universal seal kit to stop the leak and noise.
Just got caught up on the build from the beginning. It’s a great build, I appreciate all the photos to go along with the write ups. I wanted to get caught up ‘cuz I’m headed over to the 2,000 mile thread next. Looking forward to the next update.
