Street Build Salty Seagull's RS to GS Upgrade
Ownership Status
Currently Own
Mitsubishi Eclipse N/T
Drivetrain
FWD
Automatic
Build Type
  1. Street
Mods-Engine
NTK Camshaft Position Sensor (August 2021)
NTK Crankshaft Position Sensor (August 2021)
Knock Sensor (June 2022)
Interstate Battery (August 2021)
Mahle Engine Gasket Kit (MLS Headgasket, valve stem seals, etc.) (June 2022)
SBI Valve Keepers (June 2022)
SBI Valve Springs (June 2022)
Gates Timing Belt (June 2022)
Gates Idler Pulley (June 2022)
Bando Serpentine Belt (June 2022)
Bando A/C belt (June 2022)
ATP Exhaust Manifold (June 2022)
Denso radiator (June 2022)
Gates upper and lower radiator hoses (June 2022)
All new rubber hoses (June 2022)
Mods-Drivetrain
OEM 16" 2GB GS Wheels (MR333791)
Goodyear Eagle RS-A Tires (August 2021)
Cardone axles (left and right) (September 2020) - to be replaced with OEM (TBD)
Moog inner tie-rod ends (left and right) (June 2022)
Moog outer tie-rod ends (left and right) (September 2020)
Moog steering rack bellows (left and right) (June 2022)
Parts Wishlist
OEM.
Background
I'm the third owner of this stock, nearly rust-free 1999 Eclipse RS from Arizona, which had 96,615 miles on the odometer when I purchased it in July 2019.
The car already had the Preferred Equipment and Power Packages from the factory, and I plan to restore it to showroom condition and (mostly) upgrade it to the GS trim level with a few personalized touches. My goal is to keep it stock though, preferring OEM parts for any upgrades.
Major Maintenance:
- September 2019: Spark plugs, spark plug wires, air filter
- September 2020: New outer tie-rod ends, remanufactured axles
- August 2021: New wheels, center caps, and tires, new battery, camshaft and crankshaft position sensors
- June 2022: Engine seal kit & MLS head gasket, (4) motor mounts and cushions, radiator, radiator fan motor, upper and lower radiator hoses, coolant reservoir bottle, timing belt & components, serpentine belt, A/C belt, oil pump, oil pan, coil pack, spark plugs, transmission filter, fuel filter, inner tie-rod ends, exhaust manifold, valve keepers, valve springs, thermostat, steering rack bellows, EGR valve, knock sensor
- August 2022: Transmission output shaft seal, oil drain plug
- June 2023: OEM front bumper cover and reinforcement, GS air guide, fog lights, Passenger Front Fender Liner, Headlight Bulbs
Videos
Salty-Seagull
More in 2G DSM
More from Salty-Seagull
Share this Vehicle
