twicks69
Supporting Vendor
- 4,333
- 2,073
- Mar 12, 2004
Milwaukee,
Wisconsin
Well, if it's a bullshit design, and to my knowledge it has had 4 damaged shafts including both of yours, out of like 600 or 700 or so that have worked just fine with no issues, I would say it works pretty good.
It does come down to machining in alot of cases.
The 4-post ones get issues too, even when you use a factory rear pinion shaft machined to fit, like the shaft TRE does. The speed design ones failed regularly.
Jack's and Shep used stock cross shafts machined down without a heat treatment and it failed quickly.
If you want to make a better part and sell it, go right ahead Kurt. It doesn't bother me. I only was trying to make a good product for the community when it was designed about 14 years ago.
. Got you. I have been breaking in the tranny the gears whine, but its nothing like all this mess posted on the internet I have fell in love with the gear ratio. Yeah, ill keep you updated but not going to abuse it just to see if it will break as some are proposing, but I will drive it hard from time to time when the need arises. Overall very satisfied with tre services I just had to be patient as Jon did what he does best.
