Artago
- 2,094
- 31
- Nov 30, 2006
North Vancouver,
BC, Canada
Hi all,
I have a Forge 1G BOV recirc with yellow spring (15-23psi spring) and 2 shims installed.
At around 5-10 psi when letting off the throttle it flutters likes crazy.
I've read other threads and most say that it's to tight and that I should loosen it up. Either by installing a weaker spring or removing shims or both. Although this should get rid of the flutter it will also cause the BOV to leak at higher boost.
My question:
Is there a way to stop BOV flutter at part throttle while still holding high boost around 20-22psi?
Thanks all,
Tom
My question:
Thanks all,
Tom
, so you only need it locked at high throttle and high boost. I think the 75% TPS will work fine as is, if anything needs to be adjusted you'll be raising the boost limit if it still flutters at a ~15 psi release.
