Stock Temperature Gauge
triggerx
364
10
Aug 15, 2009
Gilbert, Arizona
Well it hasnt worked in a while so thats my next project.
So Maybe you all have a solution, but heres what happened.
The car overheated, as an attempt to get the car to cool down, someone added more water to the coolant resevoir. (the one with the 15lb pressure cap on it)
After this water was added the stock temperature gauge in the car has cease to work.
Anyone have an idea?
I was thinking a sensor may have gone bad by adding more water to the already boiling water and the steam possibly messed it up.
If thats the case I have no idea what sensor to replace.
Its a 90 Eagle Talonn TSI AWD.
You'll want to replace the bottom sensor and MD091056 is the part number from Mitsu.
:dsm:
That top gauge is to the temp sensor for the ac I believe. I know that I've disconnected it with no ill effect on the temp gauge or throwing a CEL for the ECT sensor. It's not connected for all three cars I have in my yard. But the bottem one is for ECT to the ecu. To the right of that facing the motor from the front (the one spade plug) is for the coolant gauge. . . At least for a 1g car. . .
Personally I've never had any of them fail to work. I've never had one with less than 100K on them. Half were over 180k.
If 'steam messed it up', then liquid h2o would have killed it long ago ;). . . I can see sloppy hands not holding the coolant container steady when pouring it in and pouring fluid over the plug contacts. All the coolant sending units are there on the elbow. Except for the fan coolant sending unit, which is at the base of the radiator.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
