Temperature Gauge
ShadowRS99
121
Jan 31, 2011
Mobile, Alabama
My temperature gauge never goes above halfway.
I have replaced all of the sensors and I have no leaks.
I have even tried unplugging the fan and letting the heat get high but I still won't read above half way. I would certainly like to know how hot the engine is too since at the moment it is the only diagnostic gauge I have because it is the only stock one. (2gb N/T)
True, but wouldn't running it for almost 4 minutes without the fans plugged in run up the heat a bit?
I tried that to see if I could get the heat up and it did the same thing it always does. That is what is throwing me off.
Halfway on my gauge is like 235* so needless to say i never get there either.
the stock gauge only sees a narrow range of temps so until its way overheated the gauge isn't going to move past halfway. Buy an aftermarket gauge and you will see that most cars sit around 170-190 depending on your thermostat.
Most likely it is insensitivity yes!!!! I can run my GSX without the fans running for an easy 30 minutes on the highway before I see much of a gain in temp. If you dont have any problems with it getting up to normal running temp then you should be okay. You can always get a diagnostic tool and double check just to sooth things over.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
