stock 2g alarm and starter/ignition problems
orzech
91
Aug 23, 2004
Honeoye, New York
okay the only way i cant start my car is if i use a jumper wire instead of the relay that is behind the cd player in the dash. My starter works turns over fine when i get rid of the relay. So i bought the new relay plug it in and still power cuts out and the engine does not turn over.
But the keyless entry buttons lock and unlock the doors but there is no horn noises when i lock or unlock or anything like that when i hit the button a bunch of times. But when i unlock the doors the dome lights turn on and turn of when i lock. Wut is up with my stock alarm system? Where can i check for problems b/c obviously it is disabling hte igntion and i dont want to #### anything up by not having that relay piece in there.
THanks
Chris
problem solved thanks a lot guys. It was the clutch disengagement. I tried starting with the clutch down with the bad relay and it didnt start. Then with the new relay i only started in nuetral and never pushed the clutch down. Thanks
Chris
