xxShaneOmac
- 423
- 0
- Jan 2, 2007
Everett,
Washington
Car would die every 4 days of not being driven, took out my battery and Autozone told me it would not hold a charge so I purchased a new one and put it in the car.
Grabbed my laptop and turned the key to on, loaded my ECU file for DSMLink 2.0 and started the car. It instantly goes to 14.7 AFR and idles at 1k perfect for 2-3 minutes.
The next time I looked at my AFR it was 11.0 and holding solid while at idle and 0 throttle. I had in the meantime adjusted some settings in DSMLink but none of them were to do with fuel. I tried to give it some revs to see if it would come of it and then drove it for a second. After 10 seconds of driving it died on me. Started again and it was a strong start and put it in gear and drove off and once I let off the throttle it died again. 3 more starts to get it back into my driveway each time it dieing sooner and faster than the last when I was not giving it gas.
Trying to start it now and it will never catch unless I feed it gas and it dies the second I let off the gas.
Looked over my DSMLink and all settings are correct, -46% global 330 deatime (tried 420 as well) My Invert Cas is not grey'ed out (tried it with it greyed out, not sure what way is right for a 99eclipse with a 95eprom) nothing worked. Checked my AFPR and its at 43.5 w/o vacuum like it should be.
I smell a good amount of gas around the car and with what my AFR was saying it was rich. I assume my stock o2 sensor is going out and its messing up the readings and my car is not getting air at all.
Any other ideas or ways to prove that? Also, could someone let me know if I should have Invert CAS grey'ed out or not on the link?
Thanks
Thanks
