starting issue
mitsu_matt
214
Nov 7, 2005
Lyon Township, Michigan
AhhhhH!!!!! just got the motor back in after having it out now it will not start.
When you turn the key to the start position i hear the starter relay click, then you hear the fuel pump turn on, but not start. I jumped a wire from the battery to the starter (s) and it worked. Also i checked all the fuses and connections. I also disconnected the clutch wire connector. When i disconnect the starter relay it did nothing when the key was turned to the start position, so I think all of those things are in working order.
I have read about the security system maybe being part of it, but do not know what else could be wrong. Please help!!!!
ok, i think i have narrowed it down to the Black wire with yellow stripe going from the starter relay to the starter solenoid. I tried to do a continuity test and got no continuity between.
Is there a fuse or a fusable link between? Is there anything else that might control that wire?
is your car a 5 speed if so you might want to check out the connector on the clutch peddle its like a neutral saftey switch if you unplug it and jump it out with a paper clip
also check your grounds there should be one that comes from the starter that runs to a bolt on the tranny
is that not the Clutch safety switch? Yes I unplugged it, but i thought you were supposed to just leave it not jump it?
Also doesnt that ground run from the tranny bolt to the battery?
****SOLVED***
Looks like the little black wire with yellow stripe need to be plugged in on the wiring harness and to the starter! duh! :)
