Starting, Idle, driving issue's
i had a problem with mostly witht the same problems on my 98 gst.. do u get a check engine light? if so get the code.. mine said it was a lean mixture and the second code was a rich mixture.. found out it was my camshaft position sensor
Well after this issue started happening I thought it was the fuel pump. So I took it out and swapped. And the gauge never worked after that. It seemed like the float lever thing on the fuel pump was hard to move.
my 2g had the same problem for some time last winter..it would take two or three cranks to get it started in cold and hesitates when i was on the throttle at idle..turns out my CTS connector came off. slide the sensor back in and BAM!
Well scratch the MAF, I measured the resistance on the actual sensor, but I re checked it and it is reading now. So I took the PCV off and tried to rattle it and it doesnt, its sticking so im going to try and clean it. I dont think this would cause such a big problem would it?
I cleaned the positive crankcase venilation and the car started up quicker and ran a little better but I am going to drive it to my other place cause I have moved and ill let yall know if there is any improvement. Also going to pressurize the waste gate to see if it opens. Also going to check the purge control valve today.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
