sputtering and dying tsi! Help!!
conor14
45
Mar 24, 2011
st. albert, AB, Canada
So my TSI when in park idles fine, but then when you start driving and going 20km or faster it starts to sputter and then die.
i replaced the alternator, bought a new battery and its still doing this, any ideas?
Could be a variety of things
Boost leak
Spark plugs and/or wires
Fuel pump
Fuel filter
We need a little more info on the problem.
its completely stock, running stock boost,
But why would any of that cause the battery to die?
by dieing i dont mean the car shuts off i mean its drained of all its power and the battery wont have enough power to turn it over
Check for loose connections. I did a battery relocation on mine and forgot to tighten up the cable to the distribution block. If i went over 60 or went wot it would sputter, die, and not want to crank. Also try mpi/mfi relay.
Did you buy a new alternater or get a used one? Could be also the the single wire is that has a nut to hold it on may have a break in it some where and could be grounding out. I would hit that with a volt meter and check that out.
it was a rebuilt alternator from Napa, Im Gunna go check all the wires this morning and then see if i find anything, thanks for the input everyone!
did you test your new alternator to see if it charge it might be new but it does not mean it work fine
