Speedo doesnt work
eclpsegsx12
214
Feb 16, 2003
Tucson, Arizona
My speedometer doesnt read anything. My tach works but not the speedo. The sensor is plugged into the speed sensor so i dont know. I did pull the sensor out so it wouldnt get busted when i took the tranny off and i put it back in and it doeant work. any ideas?
Is your odometer working? If not then obviously it's either the sensor, the connection, or the cable itself. If so, then it could be the speedo is broken.
I would start with checking power at the sensor. Then replace it with a known working sensor. If that doesnt work then it could be the gauge. If it worked before you took the car apart and now it doesnt work then my guess is you messed something up. I would start with the wiring
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
