2G Speed Sensor for DSM Swap
3dd13
Mar 27, 2022
Easley, South Carolina
I'm doing a 4G63 head swap on a 1991 Mighty Max using the head, ECU and wiring harness from a 1995 Eclipse. The ECU has an ECMLink EPROM. Do I need a vehicle speed sensor to be able to tune the ECU properly? I'm using the original 5 speed manual trans.
I know that if you plan to use launch control you will need a VSS. now that i think about it if you are driving along w/o a VSS once you hit your set launch control you wont be able to go past it because the ecu will see zero wheel speed. id recommend getting it/ making it work
