Mello
- 1,582
- 744
- Jul 4, 2003
Albuquerque,
New Mexico
Reviving this since my SS-B clutch only made it 9,366 miles before it was toast, slipping, not enough holding to make it up the driveway. Power not much. Elevation 7000 ft, 15psi best with 91 pump, no racing, no launches, daily stop & go commuting. Other than only lasting almost (but not quite) 10K miles, clutch drove great. You'd think it would have made it more miles.*Specific model used
---Pressure plate type:
-->SS-Series
---Disk type:
-->B-Series full Ceramic
*Specific model flywheel used
-->ACT Streetlite Chromoly
*Duration of usage AND mileage on clutch
-->75 miles. still doing breakin
*Power levels and Drag ET's/MPH if available
*Usage Type
-->Daily Driver (still doing breakin)
*Short personal evaluation of the clutch you chose
-->Would you buy the same one again?
A little premature but so far, yes-->Would you choose a different pressure plate next time (higher or lower clamp force)?
Hard to say but probably not on this application. SS is good.-->Would you choose a different clutch disk friction material next time?
Same as above.-->If your clutch wore out, how long did you have it for and mileage before it wore out the actual friction linings as a direct relation to usage, not due to other circumstances like hydraulics, pedal assembly or adjustment issues.
n/a
