GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
After owning my car for a month, here are some things i find uncomfortably odd... let me know what could be the cause and/or what may need attention asap or in the near future.
1) Second gear is weird to go into. The ideal shift is when i gently get past the synchro, then shove it into gear really fast. no noise no weird feeling. If i take too long to engage the gear after passing the synchro, it sorta grinds, or feels really notchy. doesnt grind, but doesnt feel as good as 1, 3, 4, 5... has no problem going into any gear at a stop. (obviously has a problem accelerating in any gear but first from a stop
2) reverse is also a little weird. most of the time it is ok, but sometimes, i have to let the clutch in a little bit so it engages smoothly. seems like something may be out of alignment. it wont grind, unless i dont engage the clutch a bit while shifting back. it will grind sometimes (like 1 out of 5 times) if i dont "double clutch" into reverse, and the shifter is stuck between neutral and reverse. I have gotten used to this so the grind is a very rare occurence now.
3) When I let off the brakes, i hear a click. only with the windows down, air/stereo/noise-makers off i can hear it. if i am parallel parking for example, it will go away after the 3rd or 4th press. same with sitting still in the driveway and pumping the brakes (engine on). once i get moving, it cannot be heard (because of road noise i assume) but after getting above about 5 mph, the click will reset and start clicking on release (once per release)
4) I put a subwoofer in. 1000w rms, paired with a 1000wrms amp. one time while bumping hard for 15 minutes, and driving under 3k rpm, no boost... the radio cut out, like it reset itself. is this a factory "self preservation" feature? last car i had "outbumped" the whole car died with/before the radio, that car was an 85 vette, and a 91 saturn sl2.
5) After heavy rain, the hatch stores a little bit of water under the plastic trim. when i pop the hatch it all pours out. there is rust on the rear windshield wiper motor. i assume the wiper seal/gromit is the culprit. confirmation? if i wait a few days, the water eventually dissapears and there is no drip when i pop the hatch.
6) Drivers window goes up 3/4 way, then looses alignment. I usually just back it down a bit, push the window back into alignment for that last 2 inches, and i goes back up perfect the rest of the way.
7) door/hatch/glove compartment lock heyholes are sometimes a pita. i guess some graphite type lubricant will resolve that.
)2) reverse is also a little weird. most of the time it is ok, but sometimes, i have to let the clutch in a little bit so it engages smoothly. seems like something may be out of alignment. it wont grind, unless i dont engage the clutch a bit while shifting back. it will grind sometimes (like 1 out of 5 times) if i dont "double clutch" into reverse, and the shifter is stuck between neutral and reverse. I have gotten used to this so the grind is a very rare occurence now.
