so i finally built a tubular manifold.......
Nice, looks like all the clearances are good. Have you tried to put a coupler on the turbo housing next to the mount yet?
yep the intake pipe has been put on............ its not straight is a s shape. it comes off the turbo then curves up and then over again. pretty much in th area of the stock filter housing.
mike
Awesome work, wish i had the materials and skill to do this.
finished!
well for being my first one i think it turned out ok, practice makes perfect though. anyways here it is along with a few other pics. what u guys think.............
i had to take pics of those ports before while it was off.............
the
motor mount mod..........
the hood mod...........
over all shot as it sits..........
this is the best weld on it IMO.............
overall manifold shots..........
well its obviously going to face downwrd and the dump goes right in front of the intake pipe and then it curves backward once past the intake pipe and slips right between the motor mount and the longitudinal under engin brace thing. :thumb:
mike
That's a super clean job for a DIY header! Did you previously have the OEM passenger side fan removed? (the big one) The reason i ask is that when i did mine and put the same slim line on it that you have, i constantly overheated if i tried to use the air conditioning. I ended up rotating the outlet to the top and was able to trim the fan's upper left corner to fit the IC pipe in there and now i have my AC back with no cooling issues. That one large fan is very valuable IMO. But if you're not worried about AC it'll be just fine. Still a damn good loooking header if you ask me. I'd proudly sport that instead of my cast Turbonetics unit :D
I'm shooting you a PM, i got a little neon project in the works and need your help.
yeah the over heating thing has been brought up before so im now pretty sure we may have issues with that. but if we do well get it figured out. pm'ed back sir
mike
mmmm Knife-edged :p
Manifold looks great, I hope to see more of your work!
