turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Ron, would 308 be only used when doing 304-to-304 then? Which rod would you use when doing 321-to-304?
Thanks,
Tim Z
You should use ER308L for 321 to 304 (it's made for 304, 308, 321 and 347 stainless.)
Your other option would be to use ER309L this is for bonding various alloys of stainless to each other or for joining stainless to mild steel. (mainly 309 and 309 clad and SS to mild)
Myself, I would use the 308, it's plenty strong enough for the application and bonding 321 to 304 sin't really a big deal, the differences in them are pretty minor.
The important thing is going to be to either back gas purge the inside of the joint with a continuous flow of argon while welding it or giving it a liberal coat of "solarflux-b" on the inside of the weld seam if you don't "back gas" it
