stephen p
- 47
- 0
- Jul 7, 2009
pearl,
Mississippi
hey, guys.. i'm new. i'm not completely new to dsm's, as i've had a few 1g m/t awd cars.. i
just aquired a '97 tsi awd, A/T. it has some basic mods, it has the road surge manual shift box, ets front mount, forced perf evoiii 16 g, 3 inch exhaust, stainless 02 dump.. any way, boost is set on wastegate spring (10 lbs)
the car just feels like a turd. it's not as bad from kick down, but a from a dead stop, that's an entirely different matter. when i stall it up, it will build about 7-8 lbs and when i release the brake, its horrid. it could probably be out 60ft'd on a bicycle (no joke) it does not really start pulling noticably untill 3-3.5 k. the check engine light is on, i have not had a chance to pull the codes (i got the car about 2 hrs ago) any way, i was just hoping there might be an obvious "check this" type answer
and it's not a matter of me having really high expectations for the car, but something is noticeably wrong.. driveability wise it's ok, and it will merge with traffic, but something's off. like maby it's pulling timing or something
EDIT. so now the car is running horrid when it get's to boost. if i feather the gas, and let the gears wind out, it drive's ok, but if i give any throttle, and it goes into boost, it hit's a brick wall, and stumbles really bad.. bad maf?
f course you will not see the greatest low end..But when in boost it should feel right..3rd,Are you launching in 2nd or 1st? How long are you brake boosting for?
