shift linkage replacement
stheodore10
78
Apr 3, 2012
Hillsborough, New Jersey
searched and searched to no avail. im looking for a how-to hopefully with tips on how to do this on a 92 talon. im having an extremely hard time removing the linkage out of my junker and cant imagine the linkage in my project with full interior and the engine actually in the engine bay to be much easier :idontknow: any and all help appreciated, thank you
EDIT: not sure if anyone can actually solve my problem at the origin but: i cant shift into 1/2/5/r and i found it to be one of the links bound up
What specifically are you wanting to know, it is very straight foreword. Remove the console and you will see exactly needs to be done. There are only 2 bolts holding the cables to the firewall. Each end just attaches with a cotter pin and a lock clip.
You're gonna need to remove the center console and might as well pull off the carpeted side covers. To make it easy on yourself in the engine compartment you'll want to pull the intake off to give you room to work.
