Screeching Sound When Turning
Zoned
Jan 18, 2014
Napa, California
I just finished installing a new timing belt. Everything seems good, except for when I turn the steering wheel all the way over to the left or right had side. The screeching noise will continue if I continually hold the steering wheel while it's at either end of the turn. This sound never occurred before I did the timing belt job. Obviously, I had remove the drive belts and power steering pump out of the way when I installed it. Should I try replacing the drive belts? I reused them but I forgot to mark where they lined up with the pulleys.
Holding the steering wheel at full lock in either direction puts unnecessary load on the engine and steering system and can make a noise if not properly adjusted as already stated. You also don't have to mark your accessory belts to line up. Just for direction if you re-use them. I'd check to make sure your steering rack isn't leaking as well. That's the problem I have with mine, even after rebuilding the steering pump.
Make sure your accessory belts are tight enough. Possibly low on fluid? As stated do not need to line up just make sure they are still going same direction if reused.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
