SAFC controller
GOTNOS
93
Nov 29, 2004
scranton, Pennsylvania
Does anyone know if the Apexi SAFC will work with the stars kit? I was told it might not but to try to find out because of the map unit used to make the turbo work.
Don't use a missing link or anyother MAP altering device if you are using the SAFC... USe one or the other. The missing links alter the voltage reading so your PCM doesn't see it, The SAFC uses/reads the voltage from the MAP sensor.. correct me if I'm wrong, hope this helps
