Saab 350cc/min 33lb/hr for a 420a turbo
eleclipse99
84
4
Jan 14, 2010
c, Europe
hey guys, well i have 4 fuel injectors from a saab, they are 350cc/min 33lb/hr red tops, all i want to know is, if i can use them on my 420a with a Vortech SFMU,for 6psi DD and 8-9 psi on the track? or are they too big?
here is the injectors specs.
INJECTOR SPECS:
Part number: 0280150431
Brand: BOSCH
Design: EV1 4 Hole Disc Type
Connector Type: EV1
Flow Rate 33 lb/hr
Ohm: 12.0
Dumb for me to ask, but can you break down what all those numbers mean?
The numbers /hr thing?
Sent from my T-Mobile G2 using Tapatalk
What turbo are you going to be running with those? In case you don't know, a large enough turbo can over run those at even 8psi.
Let's say you wanted to do it on a EVO 3 b16g you wouldn't be able to run the wastegate pressure with those. That turbo on 450cc injectors is pretty much maxing them out at 10-11 psi.
If you were going to run something like a 13g or a t-25 I don't see 8-10 psi being a big deal, but I may be wrong because I don't know the flow rate for either turbo well enough to give a good solid answer. I can how ever give you an idea of how to find out.
Vfaq, has all the MHI turbos flow rates listed on their site. There is a calculater that calculates airflow by CFM, and then you put desired boost level and your injector size and fuel pressure. If i remember right it gives you the injector duty by a rough estimate. Hope that helps.
Thank you for clearing that up. I need to learn this kind of information in the long run
If you don't mind me asking, what turbo are you wanting to run and what kind of power goal do you have?
thank you guys for the reply.
You can use your stock for those levels of boost.
so, i can use stock fuel injectors and the SFMU? or i don't need the SFMU? the reason i want to run the SFMU is because, i want to be safe and not brake nothing, because my engine is stock on everything
i want to run a Garrett, compressor .70 a/r TO4E cover i believe is a 57 trim. turbine side maybe .63 a/r Looks to be a T31 turbine wheel
right now i'm running 4psi :p but i want to run 6-7psi DD safety
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
