AFX ECU for a 420a TURBO
clipz97turb0
Jul 19, 2008
salinas, California
i have 1997 eclipse turbo i just want to know if this will give me any performance i ask the guy see if the AFX ecu will work on my car even if my car was boosted because i have heard that the AFX ecu was really good if your car was NA but i just want to know if the AFX will help with my perfomance even if my car is boosted because this us what the guy told me
"Hi, yes it will work on your car, but you will need to retard the timing with an MSD if you are boosted. Please let me know if you have any other questions. Thanks"
and this is the link for the ECU
eBay Motors: 420a Mitsubishi Eclipse Howell AFX Racing Computer ECU (item 300256613547 end time Sep-13-08 18:00:02 PDT)
AFX ECU is an NA application. Doesn't make sense to buy it THEN buy something to offset the reason you are buying it (the msd ignition retard plus you will need to adjust fuel). You are better off just buying the msd and allowing for ignition adjustment.
BUT if you are going that far, you may as well just buy the MSnS. That allows you to adjust everything.
MB
