nmg72
- 30
- 0
- Nov 26, 2012
Mobile,
Alabama
Ok, I did some reading and I have a question about the Russell ProClassic Nylon Braided Hose.
Some people are reporting that you can smell gas emanating from the hose. Others have reported that the 15% ethanol gas is eating away the rubber internal hose. They recommend using a PTFE (teflon) lined hose.
Most of what I'm reading is that PFTE is meant for brake lines, however, people are using it for fuel lines as well? Any thoughts on that?
One issue that I read was that the PFTE hose is a little smaller than a hose like the Russell ProClassic. With that in mind, will the hose adapters from the STM kit still work on the PFTE hose?
This is the hose that was recommended:
Summit Racing® PTFE Hose SUM-220985 - SummitRacing.com
. I've had zero issues with fuel smell using both 93 and switched to E85 several thousand miles now.
