Nicg
- 0
- May 30, 2022
Port orchard,
Washington
I need some advice or anyone with any other ideas from experienced dsm guys. I have a 97 gsx and I had my clutch replaced with an act heavy duty kit about 6 months ago with approximately 4k miles on it. A few months ago and I drove it the other day and noticed a reeking smell from the transmission of burnt rubber almost as if you did a huge burnout. Not a clutch smell. I also replaced my slave and master cylinder as long with a ss braided line crime master to slave. I have made absolutely sure that the pedal adjustment and slave adjustment is up to spec. This only happens while under a load and I have noticed almost no slipping from the clutch. I drained the Trans fluid and noticed a bit of shavings. Not a super alarming amount but enough where it’s not normal. I am at a loss I have never ran into this before and I was a tech for 5 years. I want to know what you guys think before I pull the Trans and take a look at it myself. I do not completely know for a fact that it was shimmed and the condition of the pivot ball. Has anybody else ran into this issue? My gsx is completely stock with only a few bolt ons. Really hoping the trans isn’t broken the car only has 90k original miles on its 2nd clutch
