[RESOLVED] UGENT: Crankshaft Turned Counterclockwise
ab dsm
Dec 1, 2011
Aurora, ON, Canada
Hey there,
I have turned my engine counterclockwise by the crank while I was doing a timing job... :( I turned it backwards about 20 rotations of cam gears worth with the belt ON to line up timing marks... did not skip any teeth through...
Damage???!
Help please don't want to start like this :(
Dont turn it that way again. As long as you can turn it 6 times clock wise. TDC to TDC and all marks are right on, its good enough to run. Locate TDC again and spin it 6 times, when you do that, and it lines up you can start it. Dont worry you should be good but dont get in the habbit.
How many of us turned the crank the opposite direction like this and survived?
Some installs recommend a light counter rotation to set tensioners then do the rotation to check mark alignments.
You're good. Good luck - DSM
As long as the belt was attached you should be ok. Now if the belt was off, that's another story...
Thanks so much guys... so many cautions for clockwise I thought I'd messed something up real bad...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
