General [Resolved] No timing advance, I am stuck at 5 Degrees.
4g63mightymax
211
3
Oct 2, 2002
Townsend, Massachusetts
I am sorting out a few bugs on my 2nd 4G63 Mightymax build, and I have a problem that I am stuck on. I have a completely stock 1991 4G63 turbo engine with a 90 ECU (with the two wires swapped). I use MMCD v 1.8 on my Palm to read my engine info and my timing is stuck at 5 degrees. No matter how I drive, or what I do, it is permanently at 5 degrees.
I can even turn the CAS and have the Palm still show 5 degrees timing. My timing light tool adjusts normally when turning the CAS. I have swapped ECU's and CAS's with absolutely no difference. My ignition timing ground connector is not grounded, and if I do ground it, the engine doesn't change rpm, sound, or anything.
I don't have my VSS wire hooked up and I don't have the coolant sensor that goes between the thermostat and the radiator cap hooked up either. Other than that, everything is wired up just like a 1991 eclipse.
Has anybody come across this before?
Steve the wiseman / computer guru, any ideas?
Thanks in advance!
-Jeremy
I sure did, but I will definitely double check to make sure that I am not doing this :beatentodeath:
Have you actually seen this happen before with it on the 3000gt setting?
-Jeremy
I definitely have my logger setup up right, and I even tried another one to see if mine was toast. Unfortunately for me, both loggers work and my timing is still stuck at 5 degrees.
I did hook up the other coolant temp sensor and it made absolutely no difference at all.
I am baffled, does anybody have any new thoughts on this? I feel like I have tried everything.
Thanks
Jeremy
If I set up the timing light, and turn the CAS, I can watch the timing change. Then if I go plug in my Logger, it says 5 degrees no matter where I set the CAS at. The real problem here is that the ECU is not doing anything with the timing. It is stuck at 5 degrees, and not advancing when I drive it.
If you were to plug in your logger, it should show the timing bouncing around and you should be able to watch it advance then retard when you floor it. Mine doesn't. It is 5 degrees all the time. This makes my 4G63 Truck very very slow. I am guessing that the ECU is seeing something that it doesn't like and preventing timing advance.
I have tried a different ECU, CAS, and logger and they all have the same results.
I wish I knew exactly what causes timing advance to work and which sensors are involved. I don't have a check engine light or any fault codes. I have the truck wired exactly like a 1991 Eclipse should be, and this is the second 4G63 truck I have built. My first one ran great.
Any new ideas?
-Jeremy
Jeremy and Nathan,
I'm going to PM our resident ECU guru (steve) and see what he thinks. It may take a bit, but he always manages to figure things out.
Andy,
I greatly appreciate it, and as for the other post, the ignition timing adjustment connector is not grounded. I can follow it all the way back to the ecu and it is a single wire, not touching anything else. Whether it is grounded or not, the timing is stuck at 5 degrees. Grounding that terminal makes no difference at all in how the engine runs.
Keep the ideas coming!
Jeremy
For those of you following the 4G63 Truck timing saga, here is today's update. I had a few minutes this morning to mess with the truck, and realize that I had a wire hooked up wrong.
It turns out that the black w/ yellow stripe #6 (I think) wire in the MPI relay was getting ignition power instead of power ONLY when the starter solenoid was working. This was causing me to feed power to the MPI relay all the time and telling the computer that the engine was constantly in the "start" position.
The computer starts the engine at base timing, which is 5 degrees. Therefore my engine was stuck at 5 degrees all the time, no timing advance. So now I just have to reset my idle (because it is slightly higher than I like) and get some more gas in it, because I ran it out in my driveway.
Thank you for any and all help that I had along the way.
Case closed (for now)
-Jeremy
For those of you following the 4G63 Truck timing saga, here is today's update. I had a few minutes this morning to mess with the truck, and realize that I had a wire hooked up wrong. It turns out that the black w/ yellow stripe #6 (i think) wire in the MPI relay was getting ignition power instead of power ONLY when the starter solenoid was working.
Hello. where is this black and yellow wire? under the inner panel in the glove compartment?
I'm going to assume he means that the Black/Yellow wire to pin 108 on the ECU (and pin 9 of the MPI relay) was somehow connected to the output of the MPI relay so it always saw 12v when the car was running.
Since he had a MightyMax he swapped I'm not sure where his ECU and MPI relay were located. On a DSM the ECU is located in the center console and the MPI relay on the passenger side of the center console.
Perfeito, consegui localizar.
O problema ainda persiste, o carro fica apenas em 5° de avanço. Travado. Ora 4.5 ora 5.
O fio preto com faixa amarela tem negativo nele.
Um conector de fio unico que esta por baixo da mangueira da tbi.
Perfect, I found it.
The problem still persists, the car is only 5° forward. Locked. Now 4.5 now 5.
The black wire with the yellow stripe has negative on it.
A single wire connector that is under the hose of the tbi.
Resolvido meu problema!
tirei a ECU e mandei arrumar. Estava queimada.
Solved my problem!
I removed the ECU and had it fixed. It was burnt.
