snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
I was trying to set my timing tonight after haven taken out my 1g CAS to replace the o-ring. When trying to find the timing mark on the crank pulley, it would not even get in the range to be on the timing marks. When the timing is retarded the whole way, the white mark is below the 10* mark (around say +15*). It can't be retarded enough to get into the range. All of this was done with timing grounded via DSMlink.
So I thought maybe installing the CAS out 180* might cause this. So I verified that it was installed correctly according to RRE's 1g CAS in a 2g page. Still the same problem.
Then I started rotating the crank by hand (clockwise) until the timing marks on the cam gears were lined up, with the dowel pins at 12 o'clock, and the motor at TDC. But all 4 marks don't line up. When I have a ruler across them, I have the outer marks in line, but the two center ones are about 3mm below the ruler line.
Then I remembered blcknsp0oln's thread on setting the timing (http://www.dsmtuners.com/forums/art...l-installing-timing-timing-belt-6bolt-2g.html). It says in there about checking by counting timing belt teeth:
I did this and I get 39 teeth.
I also checked the harmonic balancer for any separation, but there isn't any.
Is my timing off?
blcknsp0oln said:You will know you have everything timed correctly when you count 39 teeth on the belt starting from the top of the left exhaust cam mark to the middle of the right intake cam mark.
Is my timing off?
We'll compress mine and my bro's old one and see how they compare. I do plan on doing a full timing belt job over the winter once I get some money.
