snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
I have installed the JM Fab FIAV bypass plate and have removed all emissions. I used the Motormite Bypass Cap assortment (from Advance Auto Parts) to cap off the nipples that the two coolant lines connected to that ran to the throttle body. I just started the car for the first time tonight after doing this. I also installed new radiator hoses, radiator, and 1.3 bar radiator cap (along with other things). After taking it for a little test drive, the one cap that was blocking off the water pipe nipple exploded and sent coolant everywhere. I was wondering if someone had a better suggestion as to what to use, or maybe another idea as to what I could do. I don't want to loop the two nipples. I could take the one on the housing to get welded shut, but I do not want to take off the water pipe (as that would require dropping the turbo). I also don't know anyone that has a welder.
Any ideas or suggestions would be appreciated.
