[RESOLVED] Anyone Know What This Goes To!!!
rowland2004
31
Jun 14, 2008
North Olmsted, Ohio
Hey was needing some help in seeing what this vac line might go to.
92 gsx'
the line leads to under the batt. box. thanks.
I believe the charcoal canister is under there,mines unplugged as well.
:thumb:
That is a vacuum hose that connects to the charcoal canister which is located under the battery, and if it is still in the car I suggest that you reattach it, that line feeds gas vapor into your intake and will help gas mileage.
If your car has had the vacuum lines shortened and re-routed, then it's OK to leave it disconnected.
If you're still running the stock vacuum line system, somewhere there's a line that the one in your hand is supposed to plug into that is an enormous vacuum leak at idle and boost leak when on the throttle.
