2G Replacing crank position sensor
Scraggybeard
40
Jun 8, 2013
Maple Grove, Minnesota
Replaced my head gasket and then got a no start. Didn't have spark and CEL threw off a code for crank sensor A circuit. Pulled the old sensor and will pick up a new one to put in. I noticed my crank plate isn't shiny (has brown coating on it). Do I need to try to clean this before I replace the sensor? Anything else I should check? What possible reason is there for the sensor going bad?
