Replacement part for Head exhaust stud
arbiter
159
Jul 21, 2008
Irun, Europe
I found out today that I have a broken stud on exhaust side of my head.
It's the outermost left stud of the exhaust side.
I have read something about that outermost ones, are bigger than the rest, but it looks the same to me than the others.
As usual, I have the same issue that most of usa cars got in europe, MMC dealer has no access to american VIN parts in ASA.
He think my stud can be MD031537.
Is he correct?
If it is the same as the rest, it is 8mm x 1.25 x appox 45mm long.
It should be a common enough size for you to get one.
^ Yes, the larger outer studs and nuts are 10mm x 1.25 for 7-bolts. However, the studs are all 8mm x 1.25 on the 6-bolt, which it sounds like the OP has.
