er82
- 247
- 35
- Apr 18, 2014
Sacramento,
California
I'm in the process of rebuilding the 5spd awd transmission and I wanted to remove the shift arm. It looks like there are two pins. One is spring pin which came out easy. The other seems solid and hasn't moved yet. I hammered it and it won't budge. How to remove it? Should I use a press?
. I'm not for sure on the solid pin I cant remember but I think it only comes out one way? A press doesn't give much feedback and can be a good way to break something so be careful.
