rebuild ideas
eric4g63
44
Jul 9, 2012
millers creek, North Carolina
Ok guys so I was just gonna bolt a evo 16g on and run it on my stock block but my rings and valve seals are bad. I would like to know what parts like pistions and rods stuff like that are gonna hold a hx35 at 20 to 30 psi daily thanks and it's a 90 gst looking to spend around 1000 to 1500 for the rebuild
Do a stock build it can be done but for how long don't know, just look at any vendor for a package, lots of vendors who will have what youll need, check them out. They can give you prices too.
Your budget is a bit low for a forged set up, H-beam rods and forged pistons will go $800-900 new, depending on brand.
Add $300 for the timing belt and hyd tentsioner and pulleys.
This is just a start, still need bearings, gaskets
Machine work can go $500-600 or more depending on what is needed and wanted.
Stock block would be good enough, anything other than that the cost adds up real quick. It's more of the tune than it is the motor half the time. Good luck with the build!
