Reason for transmission doing this?
Karmah
109
Feb 10, 2015
Hazel Park, Michigan
When I got my 96 gsx, the clutch pedal was adjusted to at the floor, but it never grinded or anything in the transmission; it worked perfectly. I recently changed all fluids, trans, xfer case, differential, and brought the clutch to the ideal position using the clutch pedal adjustment video. Now, 2nd gear will pop out when I first put it in, and if I slowly let off on the clutch, it will stay. It will never pop out when it gets in though, I can redline it in 2nd and it stays in and is like how it should be. What is causing it to pop out of 2nd when I first go to put it in? Every other gear is perfect.
