Rear Suspension noise
Arnie
800
Mar 29, 2012
San Diego, California
Hey Everybody I have a question.
This is how I bought the car. Before I changed the struts it made that noise and after I changed the struts it still makes that noise. I was sure after the struts were changed it would of stopped making that noise, but nope unfortunately still makes that noise.
What do you think it may be? :aha:
My rear suspension has been making noises when I drive turn corners, break, accelerate.
I just changed the rear struts.
How do I know if it is an axle or ball joints or etc?
Thanks for reading and helping!
Could you possibly take a video of it? Something is making a really wonky sound in the rear of my laser, that just started after I had some people ride in the back seats for the first time. I'm curious as to whether we have the same problem, I can't seem to figure it out on my own.
Does yours sound worse at low speeds than at highway speed?
I'll see if I can take a video. It doesn't make noise when I drive on the freeway, just on the street, at turns, when I hit the breaks/slow down,and possibly when I hit bumps.
If I don't find out, I will possibly take it to a suspension shop and see what is wrong or loose.
I also took out the spare tire, wooden cover and everything out of the trunk area to see where the noise was coming from. I am pretty sure something is wrong around the rear suspension area.
Like I hear it from the area around the rear tires. Just can't call what it is.
Is it a sort of creaking noise? If it is, then it's most likely the bushings right above the rear tire. I'm having a blank and can't think of what the arm is called... :facepalm:
Edit- okay I think I was thinking of the Upper Control Arm Bushings. They can be replaced by following these steps http://www.dsmtalk.com/forums/showthread.php?t=222152
I'll actually be doing this pretty soon...
If your car has a rear sway-bar, look at it first. After that, it's usually a torn/blown bushing. So you put the car on stands and start yanking.
Yes, check the bushings back there on the control arm/spindle assembly and the sway bar. Both, like stated above can cause noise. Actually, when I had the upper bushings on my white '95 go bad, the car's rear end would actually wiggle some (like a RWD car loosing traction) when taking turns. Thought I was going crazy... haha!
No I do not have a sway bar, but after I put them on stands, how can I tell if they're bad? Sorry if I sound noobish :S .
Edit- okay I think I was thinking of the Upper Control Arm Bushings. They can be replaced by following these steps How do I replace my rear upper control arm bushings for both sides? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Thanks bro, I will look into it right now! :hellyeah:
Thank goodness mine is FWD :p hahaha,:tease: I will get on this for sure today, don't want anything bad happening to my baby!
Thank you! ;)
Ok I looked at the bushing on the control arm. Yeah that's the issue. I looked at it and had a friend put his ear next to it as I put pressure on the car. Squeak came from that area.
Gonna order the part, then take it to get fixed / replaced.
Do I just need to replace that bushing or is there other components that need to get replaced?
http://www.autozone.com/autozone/pa...yWord=control+arm+bushings+&fromString=search
Couldn't find it on JNZTUNING, the rear suspension didn't want to open up...
Can someone give me a part #? or let me know what I should be ordering before I start spending? Thank you in advance!
https://www.google.com/search?q=pol...a=X&ei=J31jUL6iBaqw2gWfnIGQBA&ved=0CEsQuw0oAQ
I found these online and they're cheaper then auto shops. So yeah looking around waiting for an answer...
