Rear negative camber whats wrong?
xpertsoldier
44
Jul 21, 2010
Waco, Texas
I just got installed some kyb agx shocks and struts using the stock springs. I took it to get a alignment done and they told me the front inner tie rods were bad. They wanted a arm and a leg to install in. Long story short I did it myself and brought it back today to get aligned. They said the rear camber is out of spec and couldn't tell me what I need to get it fixed. It is the rear right wheel. They said its at a-2.7% which is out of spec range (-2.2 / -1.2). Any suggestions on what might be wrong or what I need to fix it? If something is bent I want to just get it fixed right. He also suggested maybe the spring is bad. I am 95% sure they are the stock spring with roughly 125,000 miles on them.
I am sure I can just make the homemade camber kits for the rear, but again if something is bent/worn I much rather just fix it. I have a 6 month 3000 mile warranty so if I can get it fixed soon I can just bring it back and get it realigned for free. Thank you for all your help ladies and gentlemen
