2G Rear diff seal replacement
Bedicine
542
192
Jan 3, 2022
Toronto, ON, Canada
Hello,
Currently trying to change the seals where the axles go in at the rear diff on a 2g. The original seals are falling apart as soon as I try and remove them. Does anyone have any tips on how to get them out. I most likely can get the top portion off but there is a lip on the outside that will be buried if the top is removed
A simple angled pry bar pops when right out(just get in behind it) then just tap in the new one flush with a socket.
RTM Racing carries them.
Hello
I do have the new ones here from rtm, I have tried getting them to pop but they fall apart with how brittle they’re
Hi Steve
Here is a photo of the new seals. There’s a metal spring inside but it all seems to be rubber
