Replacement rear diffs available?
jasonlee
164
Mar 8, 2004
Waterloo, Iowa
I was just wondering if there is any aftermarket rear diffs avaialble for 2g lsd setups out there.
Like Cusco, or Kaaz, or something like that. thanks!
There are no direct replacement LSDs for the DSM VC LSD, the inner axle stubs are incompatible. To fit any of the aftermarket LSDs (that I know of) you must change the inner joints to either Evo I/II/III parts or swap the axle assemblies for those out of a non-LSD car.
Once you have the correct axles, there are at least two LSDs available - Kaaz and Cusco, both of which are 'mechanical' or 'clutch pack' units. I have been using the Kaaz unit in my autocross car for a few seasons now, it appears to last about two seasons, then needs a new set of plates otherwise it starts slipping. The Kaaz is a fixed 1.5 way, where as the Cusco can be changed from 1-way to 1.5 way to 2-way by changing how the internals are assembled. Kaaz are available from a number of sources (eg RRE), I only know of one source of Cusco - Nukabe (napsusa.com).
Charles
