1G Rear defroster not working
So its def the switch huh? I will check the fuse make sure its not blown also check that its plugged in on the rear window havent did those steps yet if all is good there then i know its the switch besides a junkyard will a autoparts store have it or can order it? Dealer maybe?
Its just 1 fuse, possible auto store no, dealer , maybe or maybe not, if so could cost you. Best bet jun yard or ebay, try there, or look on part outs email them or call them they may have one, look around. I may have one laying around.
in a 1G, the rear defrost switch is momentary. So even if you were to replace it with a brand new one, it will never 'click' or latch into an on position.
1G's seem to have a problem with the rear windshield's defroster's electrical contacts breaking off of the glass. I would check them first. There are two on each side of the rear glass about 1' away from the rear gas struts that support the hatch lid.
If you have already verified that all contacts & fuses are good, I'd look into the rear detrost relay (located in the engine bay, next to your injector resistor pack).
the rear contacts on the window are plugged in and are on each side and the fuse is not blow so i think its gonna be the relay then?
Several years later and im running into this probelm. Where is that relay!? I cant find any pictures or nothin anywhere! I had to resolder on my contacts on the rear window and yet that did t work. Ive tried two different defroster buttons. None light up or engage. Fuses are fine? So last thing to check is the relay.
