-Really- low compression numbers
Shigun
38
Jun 6, 2007
Norman Park, Georgia
According to the guide I saw for checking the compression, I should be getting low 200s. My compression numbers are as followed: (1 - 4, 1 being closest to passenger side) 155 - 150 - 120 - 115
Now, I know I can put some oil into the cylinders to see if their numbers increase possibly, given that its a certain problem, however would that cause an increase of that much? What could possibly have my numbers so low (and varied, in the case of 3 and 4)?
low 200's? what guide are you reading?
Number 1 and 2 are fine. 3 and 4 have problems. Run the car, get it hot, do the compression check with 3 and 4 again and make sure you hold the gas pedal down while cranking. Let me know what you get. I'll wait.
Ya, sorry, I was looking at a guide for a 2G 420a engine and never actually *caught* that part, just the compression test bit. I will have to do the other bit of the compression test tomorrow for you, as it is raining rather rough outside right now.
Yeah, 150 is respectable for the 1G 4g63t. The 2G will read higher, and the N/T will read MUCH higher. And you should never do a compression test cold, unless you're tracking down a running-while-cold issue (like a mis-sealing valve in the morning) and not to check general cylinder health. Drive it around for a good half hour, boost it a bit even. Wear gloves when you take the plugs out, as they'll be pretty hot.
You count the cylinders from the timing belt over. #1 is closest to the driver, #4 is passenger side.
and uhh disconnect connect the fuel system to keep from washing out the cylinders that will lower them a bit, not to say you dont have an issue they should still be more even throughout. Do a wet compression test to rule out a piston ring issue.
You pull the MPI relay fusible link on the positive battery cable when you're doing a compression test anyway. MPI relay is what turns on the fuel pump, so no power means no fuel. :b
Still sounds like he just did the comp test cold... don't usually hear of two going low right next to each other with a properly warmed-up comp test, unless it's a bad headgasket allowing a leak between the two.
I tried to do it fairly warm, though it took me several minutes of researching what I needed to disconnect and all, and even then I don't think I disconnected the right things, because I was going on a guide for a 420a engine, which I did not notice until today when I looked back at it.
I will try again tomorrow after work, warm the car up and drive it to the end of the road and back, pushing it a bit to get it warmed up fully, then pull out what I need to and check the compression backwards this time, just to be sure it wasn't a thing of cold numbers.
