2G randomly stalls
TheFlashDSM
Supporting Member
1,106
356
Feb 18, 2010
stony brook, New York
auto gsx
stock motor
mods list:
vrsf intercooler
speed density
ecmlink full
20g turbo
255 pump
the car runs great this is the first time today this happened, but its been happening all day now
problem; i went to 7-11 turned off car, started it up reved like normal on hot start then died right away, started right back up tho,
drove away came to 1st light and as soon as i stopped the car just died and wouldnt start back up!
car sat in the road for 15 min then started back up.
here is my log, this is after i drove the car home, i hit no lights i got lucky, i went back out and it did it again at a stop sign but didnt fully die on me, i came to a stop and gave it gas and it started to die (got this logged) i was lucky to catch it on the log.
things i checked, ecu caps. no leaked ecu looks fine
take a look at my log the problem happened at the very end of the log, you will see a very sporadic drop in all sensors then bam they come back on.
ummm help please,
i just changed the cam angle sensor, the sensor behind the cam gear. from what ive read this sensor might be going bad, will see, any input welcome!
well it ran fine until i got to a light and died on me again and now wont start at all, om thinking the crank sensor took a poop, it will crank, start and die immediately.
I can't look at your log right now, but while cranking does it show an RPM signal?
I had the same issue very recently.. mine was apparently caused by a PTU that I had moved away from the heat and bolted to the front cover instead of the intake manifold. I moved it back and havent had a problem since. potentially a ground related issue? i have no idea. And I even fooled with the wiring and connector beforehand. Strangest damned thing. it would just shut off on its own like somebody turned the key.
never noticed, it cranks and fires real quick but when it does i do get an rpm signal.
PTU?
