Randomly shutting off
volcomsnow245
492
May 4, 2011
chicago, Illinois
Hey guys, I was researching a little and a few people had this same issue but no one had a good answer. What's happening is when I drive like for a good 5 minutes and stop to idle my car will just shut off. When I try to turn it over it just cranks and I can hear the fuel pump kick on. Finally I got it to throw a code and it was for my cam angle sensor. I replaced this about 9 months ago and it wasn't shutting off randomly it wouldn't start until I cleared the code. Anyone who has idea other than the cas please let me know. Thanks
Oriellys can test it ive had my N/T one tested before. i assume the others can be tested too. You can advance and retard timing slightly by moving the cam angle sensor up and down. You would want a timing light to adjsut timing correctly see the chilton manual or look somewhere else on the forums for exact instructions on how to do that, cause i havent done it before. I just made sure to mark where the cas lined up before removing it.
i would also check to make sure your wires are correctly attached and that you have the right CAS.
