Random A/T questions
1GenDSM
103
7
May 2, 2005
Watervliet, Michigan
1) I notice that I dont have overdrive while driving on a cold start. It usually takes 30-60 seconds before it appears. I know several other vehicles do this as well, so I'm guessing this is normal? If so, what regulates it? Trans fluid temp?
2) What are the signs of a failing torque converter? And what exactly fails inside?
I'll post more questions as I remember them...
It's fine and I believe it is more of and engine temp thing.
It is usually noisy in gear but the symptoms vary based on what is wrong. Internal failures are usually the bearings or the t.c. clutch.
-John
IPT Performance Transmissions
Facebook- IPT Performance Transmissions
IPT Performance Transmissions Blog
So what's the reasoning behind limiting the overdrive gear based on temp?
I've noticed that cruising RPM at a given speed can vary up to 300 RPMs between a cold converter and a warm converter. Is that normal or is it a sign of a converter issue? Also, it sometimes takes the converter a second to "engage" when taking off from a dead stop. I doubt that's normal, but I don't know what could cause it either.
The delay in overdrive and tcc lock-up (your 300 rpms) is to enable the vehicle to warm up a bit quicker and not feel like crap when the converter clutch locks with a cold engine.
As far as the other issue, I doubt it is converter related as a converter is always "engaged".
-John
Do AWD 1g's have lock-up torque convertors? Because my FWD turbo 1g didn't have it.
